jss06 wrote:Yes but you need a mppt controller.
Not necessarily true. It may be best, but may not ne necessary.
If the panels are free then it does not really matter if powered from the PV is wasted. A PWM (non MPPT) charge controller could be used as long as it can handle the higher input violtage. Yes, there will be wasted PV power but if the panels are free that does not matter much. One potential issue from doing that could be that the PWM controller may run hotter than id better matched to the panels / batteries.
OTOH, if the panels are free then perhaps the higher price of the MPPT controller does not matter as much and you could take full advantage of all the power from the 24 volt panels.
