Solar Panels, Black Friday
Postby MtnDon » Mon Nov 23, 2015 4:19 pm
Solar Blvd is having a Black Friday sale. I mention this mostly for those who want or need a "12 volt" panel. There are many places to get the higher voltage panels, 24 VDC and up. Those are aimed at the grid tied folks and can be obtained in most urban areas without too much trouble. The 12 VDC are hard to find locally and most of the prices seem to be around $1.50 a watt with shipping sometimes extra.
Solar Blvd has always had 12 VDC panels at reasonable cost, IMO. Have at look here at their linkon Friday to see the deals.
Let's see if I can paste in the email details with the pricing.....
(shipping is extra. they have a calculator on the cart page. For me it works out cheaper than any other place I have seen.
***All DISCOUNTED Prices Will Take Effect On
BLACK FRIDAY!! ***
Solar Cynergy 80 Watt
12 Volt Solar Panel
ONLY $75
(Regular Price: $104)
Manufacturer: Solar Cynergy
Cells: Q-Cells
Model Name: SLP80-12
Max Power: 80 W
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 5.36A
Optimum Operating Current (Imp): 4.65A
Optimum Operating Volatage (Vmp): 17.0V
Dimensions (inches): 33.35 x 25.97 x 1.33
Weight: 15lbs
Solar Cynergy 100 Watt
12 Volt Solar Panel
ONLY $100
(Regular Price: $125)
Model Name: PV-SC100J12
Number of Cells: 36 cells in a series (4 x 9)
Max Power: 100W
Short Circuit Current (Isc): 6.30A
Maximum Power Voltage (Vmp): 17.0V
Maximum Power Current (Imp): 5.80A
Weight: 17.6 pounds
Dimensions (inches): 44.93 x 25.97 x 1.33
Includes Junction Box And MC4 Connector
Solar Cynergy 120 Watt
12 Volt Solar Panel
ONLY $120
(Regular Price: $136)
Model Name: PV-SC120J12
Number of Cells: 36 cells in series (4 x 9)
Max Power: 120Wp
Short Circuit Current (Isc): 7.50
Maximum Power Current (Imp): 7.00
Dimensions (inches): 51.44 x 25.97 x 1.33
Weight: 22 pounds
Solar Cynergy 140 Watt
12 Volt Solar Panel
ONLY $135
(Regular Price: $159)
Model Name: PV-SC140J12
Number of Cells: 36 cells in series (4x9)
Max Power: 140Wp
Short Circuit Current (Isc): 8.40A
Maximum Power Current (Imp): 8.00A
Dimensions (inches): 39.47 x 38.30 x 1.40 Weight: 23.4 lbs
Solar Cynergy 150 Watt
12 Volt Solar Panel
ONLY $145
(Regular Price: $165)
Model Name: PV-SC150J12
Electrical Data
Maximum Power Output: 150 Watts
Max Operating Voltage (Vmp): 18.0 Volts
Max Operating Current (Imp): 8.33 Amps
Open Circuit Voltage (Voc): 22.4 Volts
Short Circuit Current (Isc): 8.75 Amps
Module Efficiency: 14.70%
Neptune 300 Watt
24 Volt Solar Panels
Pallet of Ten
ONLY $1770 ($0.59/Watt)
(Regular Price: $2370)
Manufacturer: Neptune
Electrical Data
Maximum Power Output: 300 Watts
Max Operating Voltage (Vmp): 36.6 Volts
Max Operating Current (Imp): 8.26 Amps
Open Circuit Voltage (Voc): 45.2 Volts
Short Circuit Current (Isc): 8.85 Amps
EcoSolar 230 Watt
Pallet of Ten
ONLY $1495 ($0.65/Watt)
(Regular Price: $1795)
Or 158.70 Ea ($0.69/Watt)
(Regular Price: $189)
Manufacturer: EcoSolar
Electrical Data
Maximum Power Output: 230 Watts
Max Operating Voltage (Vmp): 29.8 Volts
Max Operating Current (Imp): 7.71 Amps
Open Circuit Voltage (Voc): 37.10 Volts
Short Circuit Current (Isc): 8.21 Amps
Unik 250 Watt MONO
24 Volt SolarPanels
Pallet of Ten
ONLY $1550 ($0.62/Watt)
(Regular Price: $1885)
Or 172.50 Ea ($0.69/Watt)
(Regular Price: $192)
Manufacturer: Unik Solar
Model: JSMM2503
Electrical Data
Maximum Power Output: 250 Watts
Max Operating Voltage (Vmp): 30.6 Volts
Max Operating Current (Imp): 8.25 Amps
Open Circuit Voltage (Voc): 37.86 Volts
Short Circuit Current (Isc): 8.80 Amps
Unik 250 Watt POLY
24 Volt SolarPanels
Pallet of Ten
Model: JSMP2504A
Electrical Data
Max Operating Voltage (Vmp): 30.75 Volts
Max Operating Current (Imp): 8.19 Amps
Open Circuit Voltage (Voc): 38.2 Volts
Short Circuit Current (Isc): 8.65 Amps
50 LED Colored (Red, Green, Yellow, Blue) Solar Power Christmas Lights!
ONLY $3.00
(Regular Price: $7.99)
Easy to install, Solar-powered decorating lights are great for decorating the outdoors. They are fully articulated, so you can position your Solar Powered Flood Light in any direction.
Automatically Turns On at Night
Needs a full day charge to turn on at night for 9-10 hours.
No Wiring, Instant Installation
50 LED White Solar Power Christmas Lights!
Only $3.00
MtnDon
Images: 24
Re: Solar Panels, Black Friday
Postby lrrowe » Mon Nov 23, 2015 5:26 pm
Don, I like this find. How did you do it? I even googled for it now and did not find what you posted.
1. I might just consider ordering two 130-150W units for the CT. I do not need them yet, but will in the spring. So ordering them now may be doable.
2. Now about those 24 volt units. If you noticed my posts lately on one of the PV topic posts, I wrote about looking into running solar 24v to an off-grid water heater to feed my regular water heater/boiler for my radiant in floor system. I have not thought out all the details, mainly with how to start and stop water circulation from the off grid heater. But I am sure I can figure it out and if it has a high potential of reducing my demand for propane, then why not buy two 24V panels now on a gamble.
Bob
lrrowe
Images: 439
Postby MtnDon » Mon Nov 23, 2015 5:46 pm
As a registered customer I get preview emails. The sale $$ will show on their website on Friday only.
My rule of thumb is small systems can often make use of 12 volt panels. Use the panels in parallel connection with a PWM charge controller. Parallel panels are more forgiving if a few cells on one panel are shaded. In series a few shaded cells can lower the output of a whole series string.
Bigger systems can often make better use of the larger 24+ volt panels which offer the lowest cost per watt. However, with a 12 volt battery system then you need an MPPT controller. More $$.
Sometimes a smallish system costs about the same either way. Pay more for the smaller panels and less for the PWM controller vs. pay less for the larger panels and more for the MPPT. In this case I already have the Brat PWM charge controller I got as a beta from Midnight.
We've been away over the weekend and will get around to looking at that link to the controller and water heating soon.
MtnDon
Images: 24
Postby jonw » Tue Nov 24, 2015 8:44 am
I'm also a SolarBlvd customer and noticed these deals.
They've been a good company to deal with. I have a folding 120w panel kit (with controller, case, wiring) that had a bad controller. They send me a new, much better one that has been working like a champ since. Good customer service.
I have to take some measurements, but I'm hoping one of the smaller ones above will fit on my teardrop in between the hurricane hinge and the Fantastic Fan cover. So it will continuously charge my Optima battery when driving or parked in the sun.
jonw
Titanium Donating Member
Images: 163
Postby DaveS » Tue Nov 24, 2015 3:27 pm
jonw wrote: I have a folding 120w panel kit (with controller, case, wiring) that had a bad controller. They send me a new, much better one that has been working like a champ since.
I bought the same kit and had the same problem. Took three replacements before I got one that worked but it's OK now. The kit was a good price and came with some useful cables but I won't buy from them again. One bad part is understandable, three is ridiculous.
DaveS
Postby MtnDon » Fri Nov 27, 2015 7:59 pm
Wow! I placed an order minutes after the sale started late last night and I have the tracking number already!
MtnDon
Images: 24
Postby noseoil » Sat Nov 28, 2015 8:53 am
Thanks Don! I ordered two small panels (20 watt) just because they were cheap. I may use them to make a small suitcase setup, as a remote charging station if I'm in a shady spot & need to top off the battery while camping. Figured with the price I got ($64 with shipping included for both) it would be worth it to have a pair for future use.
137905
noseoil
Images: 670
Postby lrrowe » Sat Nov 28, 2015 12:49 pm
I went there Friday and today. To VA the shipping costs for 2 120w units was 25% of the total cost. $77 out of about $345 total. Maybe that I
s still a good deal; I do not know. But I passed.
Bob
lrrowe
Images: 439
