afreegreek wrote:you should not use a 12 volt battery.. 99% of them are starter batteries,, even the ones called MARINE are really starter batteries.. they are made to give big power flow for a short time.. batteries for camping should be deep cycle "golf cart" types.. they are 6 volt so you need 2 wired in series to give you 12 volt... two of the best battery brands are Trojan and Surrette..
dales133 wrote:afreegreek wrote:you should not use a 12 volt battery.. 99% of them are starter batteries,, even the ones called MARINE are really starter batteries.. they are made to give big power flow for a short time.. batteries for camping should be deep cycle "golf cart" types.. they are 6 volt so you need 2 wired in series to give you 12 volt... two of the best battery brands are Trojan and Surrette..
With all due respect that statements completly wrong.
There are countless manufacturers of 12v deep cycle batteries.
You are right however that most marine batteries arnt deep cycle however some are both deep cycle / stater combo batteries.
