Chello wrote:What type of circuit breakers are people using to protect their wiring? Most people seem to put one on the main line going into the trailer to protect everything behind it. But if you only need the one breaker, are you installing a breaker panel with 1 breaker in it like a miniature house panel, or do they sell some kind of inline circuit breaker for these purposes? I've looked around online and cant seem to find inline circuit breakers, but maybe i'm just using the wrong terms.
In context of mains power for small camptrailers, What you seek as an 'inline' circuitbreaker would probably best served by a DIN rail mounted circuitbreaker. They simply have line & load screwterminals.
A proper electrical assembly, it would need to be attached to DIN rail & mounted within a suitable enclosure.
Further down the list, There are numerous other circuitbreakers, using screw mounting tabs or various panel mount configuration, numerous wiring connection styles as well & Still needing a suitable enclosure.
Either of these options are easily available, But generally not at your local retail building supply or hardware store.
GuitarPhotog wrote:My 1971 Aristocrat Lo-Liner "standy" trailer has a one circuit breaker panel. It has one 15A breaker for the entire trailer. No DC, three 120VAC lights, two duplex receptacles. It doesn't have to be elaborate or complicated.
<Chas>
Chello wrote:GuitarPhotog wrote:My 1971 Aristocrat Lo-Liner "standy" trailer has a one circuit breaker panel. It has one 15A breaker for the entire trailer. No DC, three 120VAC lights, two duplex receptacles. It doesn't have to be elaborate or complicated.
<Chas>
I'm not worried about it being complicated, my main concern is space. 1 breaker wired in-line without a box would save me a lot of space.
