30amp Electrical Breaker Box and Set up question.
Postby MrBo » Wed Feb 07, 2018 1:12 pm
Hello All
Been searching for a week but most of what I found were old post with pics and links that do not work. Any help, links, post, info to get me in the right direction will be greatly appreciated.
Doing a cargo conversion with AC and DC keeping them separate. May add an inverter later but most of the time we will be just using DC with solar panel charger and controller. Everything has been purchased for this side of the system.
I have no problem wiring things up. But the incoming part to the AC / 120 / 30 amp has me stumped. Just need a good part list for breaker box. Not looking to spend a fortune, have seen many with simple breaker box. Most of the boxes I saw at Home depot were too large.
Maybe a 30amp main breaker. I want to add 15 amps to 4 plugs GFCI back to front, 15 amp refrigerator, microwave and a 20 amp plug in kitchen to be used for a heater.
What breaker box are you using for AC side? Do you ground this to the frame?
(Wondering about trailer running lights but they would never be on at the same time.)
In process of staining and poly coating the interior walls. So the wiring is the next step before I can do anything else like adding Kitchen bed and cabinets.
Any point in the right direction would be greatly appreciated.
Thanks
Mr Bo
6x14 Build Log - Rolling Thunder - Cabin on Wheels - http://www.tnttt.com/viewtopic.php?f=42&t=69971
MrBo
Re: 30amp Electrical Breaker Box and Set up question.
Postby Sparksalot » Wed Feb 07, 2018 1:28 pm
I used a small load center like this one. I only used two circuits, one fro my microwave, the other for the computer rack power strip that serves the cabin and galley. This load center could go up to 4 circuits if you used tandem breakers.
https://www.lowes.com/pd/Square-D-4-Cir ... er/3135851
A tandem breaker
https://www.lowes.com/pd/Square-D-Homel ... er/1111749
Sparksalot
Images: 687
Postby MrBo » Wed Feb 07, 2018 1:43 pm
Sparksalot wrote:I used a small load center like this one. I only used two circuits, one fro my microwave, the other for the computer rack power strip that serves the cabin and galley. This load center could go up to 4 circuits if you used tandem breakers.
A tandem breaker
Thank you!
Sent from my VS995 using Tapatalk
Mr Bo
MrBo
Postby MrBo » Wed Feb 07, 2018 3:39 pm
A tandem breaker
Thank you!
What size gauge wire do you use from the 30 amp plug-in outlet ( outside mount) to the box? I am going to use 12 gauge for wiring for the rest?
This is what I ordered. https://www.amazon.com/gp/product/B01K0NS57G/ref=ox_sc_act_title_8?smid=AIMGNG5XA4FRY&psc=1
Thanks again!
Mr Bo
MrBo
Postby Sparksalot » Wed Feb 07, 2018 3:51 pm
If you're planning to use a 30A cord to shore power, then use #10 wire all the way to the main lugs at the load center.
Sparksalot
Images: 687
Postby MrBo » Wed Feb 07, 2018 3:53 pm
Sparksalot wrote:If you're planning to use a 30A cord to shore power, then use #10 wire all the way to the main lugs at the load center.
Perfect. Thanks again
Mr Bo
MrBo
