Wattage on the Chinese park heators
Re: Wattage on the Chinese park heators
Postby tony.latham » Sat Mar 02, 2019 10:21 am
slowcowboy wrote:Still re thinking the idea so does any one know just how much juice the desil heators run on in a hole night?....and what do folks do that have them to keep up withe draw on there battery???slow.
2.5 amps per hour.
How long would you run one in a teardrop? A half hour to warm up and another half hour in the morning? Maybe a fifteen-minute chug in the middle of the night for a step-out-the-door break?
Postby Modstock » Sat Mar 02, 2019 1:18 pm
That would sound about right. It only takes a 1/2 hr to warm ours up using propane.
Sent from my H1611 using Tapatalk
Modstock
Postby tony.latham » Sat Mar 02, 2019 5:44 pm
slowcowboy wrote:Can you convert tbat to watts Tony..i am sucks at math..slow...would one deep clye handle it?.slow
30 watts. Think about a 30 watt light bulb.
Postby bdosborn » Tue Mar 05, 2019 7:12 pm
Mine draws 20 amps for 30 seconds while it's starting up. After it heats up the cabin, which takes about 15-20 minutes or so, it throttles back to low (0.8 amp-hrs). It will shut itself off and on as needed all night long so it doesn't draw as much as you might think.
Images: 806
