sounds like an invitation for gremlins to not only visit butt to take up residency in your system
IMHO it is always best to make "home runs" not having any splices in wiring between fixtures/lights/outlets
crimp on connectors were saviors when they came on the scene
they were then followed by waterproof crimp on connectors which changed the game on boat trailers by leaps n bounds
i have recently(within the last coupla years) found waterproof low temp solder connectors which i have used along with the waterproof crimp ons for wiring a boat trailer that will get dunked in both fresh and salt water during it's expected adventures
most light fixtures i use on boat trailers come with pig tails which is the only place i make connections in the system
the old standard crimp ons come in a variety of styles
- OIP.I6TN_L7ZC68xGDI7KadVBwHaHa.jpeg (11.26 KiB) Viewed 1137 times
the waterproof crimp ons look like the standard version except the plastic is translucent
you use them just like the standard units adding one more step where you use either a butane match or electric heat gun to shrink the plastic around the wire activating a waterproof sealant at the same time
- OIP.0Pwil3LFFEZB916yd5ds8AHaHa.jpeg (8.81 KiB) Viewed 1137 times
the low temp solder connectors have clear plastic w/ color coded markers and a ring of solder in the middle
you push your wires into the center of the connector in the ring of solder to where the opposing wires are pushed into each other
then you use a heat gun or butane match to melt the solder and shrink the clear plastic tubing while activating the waterproof sealant
- OIP.Jix_7yj4QsF3UzqfjtJg0gHaHa.jpeg (10.76 KiB) Viewed 1137 times
as mentioned above it is always best to have some form of easily removed covering(make it decorative and look like art work) over/at any point where any/all wires are connected in any manner
it is also best to make a loop in your run at connection points so you can pull the connector out for inspection/maintenance/repairs
BON CHANCE
sw
