friz wrote:How large and how healthy is the battery in your camper? You need a lot of battery power to run a heater.
John61CT wrote:Do NOT try to use stored electricity to create heat off grid.
There are vented "parking heaters" that burn propane or your TV propulsion fuel.
Possible to just use a non-vented prlpane unit but need to vent, use a CO alarm, and besides the danger they add moisture to the living space.
What is the voltage between the posts and are you keeping it on a trickle charger?escapingnormallife wrote:friz wrote:How large and how healthy is the battery in your camper? You need a lot of battery power to run a heater.
this is the battery I'm using. It's brand new. just got it a few months ago. https://tinyurl.com/ks8hrcun
the heater I'm trying to run (https://tinyurl.com/595pbenb) is the smallest one I could find, but I think its just surging too much when I plug it up. I'm just so novice about electricity is all.
halfdome, Danny wrote:If you want to get heat from a 12 volt battery there's the https://electrowarmth.com/products/bunk-warming-pad-non-fitted-36-x-60
They use to make larger sizes but now only 36″ X 60”.
You'll probably get 2+ nights sleep per charge of your battery.
We had a queen, then a full, and got 2+ nights on two 12volt deep cycle batteries mounted under our teardrop.
They put out a lot of heat.
Danny
MtnDon wrote:I am not familiar with Little Guy trailers. Does yours have a propane fueled water heater?
The idea in this topic still works for use in our CTC
