John61CT wrote:Yes, both the engine DC circuits and House bank should share a common "chassis ground"
This of course is not true earth ground, just a shared common reference potential.
Any important or high current DC loads should have a Negative Return wire path back to source, not relying on the chassis.
None if this has anything to do with AC. IMO the charger should be the only item plugged into shore power, all AC devices run off the House bank via inverters.
Anything more complicated hire a pro sparkie, marina guys usually more au fait than the RV ones.
NEC 551.4
(B) Voltage Converters (120-Volt Alternating Current to LowVoltage Direct Current). The 120-volt ac side of the voltage converter shall be wired in full conformity with the requirements of Parts I, II, and IV of this article for 120-volt electrical systems.
(C) Bonding Voltage Converter Enclosures. The non–current carrying metal enclosure of the voltage converter shall be connected to the frame of the vehicle with a minimum 8 AWG copper conductor. The voltage converter shall be provided with a separate chassis bonding conductor that shall not be used as a current-carrying conductor.
John61CT wrote:A purely "floating" House system is super unusual, and even if perfectly safe today may cause problems as changes are made in future.
John61CT wrote:Really in departing from mainstream conventions, I would rather ask "what reason do you have not to"?
The only cost is a length of robust wire properly terminated both ends.
John61CT wrote:Separate topic, why would you not want to be able to charge / jump your Starter from House inputs when needed?
Or take advantage of alternator charging House while driving?
bdosborn wrote:The AC battery charger case is required by the NEC to be grounded to the vehicle frame.NEC 551.4
It provides a current return path for the AC circuit breaker supplying the charger that will open the breaker if there is a hot wire to frame fault. This prevents you from being the current return path if somehow the hot wire of the charger touches the frame and then you touch it. Now, the probability of this happening is pretty low but people have been know to drive a screw into a hot wire accidentally. That's why the metal skin of a camper is required to be bonded to the frame too. I used a #12 to the frame in my camper since its a 20A shore connector and not a 50A.
Capebuild wrote:I had asked the same question a while back. You may find it helpful to revisit that thread.
viewtopic.php?f=30&t=74051#p1281706
FWIW, I did not ground to the chassis.
John
Tom&Shelly wrote:I'm late to the party but also didn't ground our DC system to the chassis. Works great!
We've never had trouble with our wiring, but, in my opinion, if we did, having dedicated wired returns would make trouble shooting easier.
As Bruce mentions, if you have a shore power connection, the chassis needs to be tied to the AC ground for safety (and to meet code). but with the charger you're showing, it's not a problem.
dmdc411 wrote:bdosborn, you brought up something I never thought of. The exterior aluminum skin needs to be grounded to the chassis ground. Especiallyif the aluminum skin is attachedto a wood structure like most of us use. It never occurred to me. I'm not a "licensed electrician", I'm a "registered unlicensed electrician". Just another way for the state to take mo money, and track my work under my employers master electrician. Without the skin grounded to the chassis ground, an ac power short to the skin would be bad. As in, if your shore power, that passes through the skin if you use an rv shore power plug, some how was to be damaged, the skin could be hot!
Sent from my SM-G970U using Tapatalk
Users browsing this forum: No registered users and 29 guests
