what are the new 12 vold wire end connectors
Postby Ron Dickey » Wed Sep 21, 2022 12:23 am
I am on my second Trailer. What I have used are the type of end connector where you put a wire at coming from opposite directions into a hole and it has a pin that perces the wire and make the connection or using open end metal tabs that are crimped onto an open wire. Many a time the crimp did not hold and had to do many redues.
What are the new ways to make 12 volt DC wires connect to a light or switch or continue a wire?? :DOH2:
Ron Dickey Cross Bow.
121377......134179
Ron Dickey
Images: 711
Re: what are the new 12 vold wire end connectors
Postby nsfr1206 » Wed Sep 21, 2022 4:38 am
I have used crimp connectors with heat shrink tubing and I’ve also used the little connectors that pop open and insert wire and pop shut. The best is likely to solder and heat shrink though…
nsfr1206
Postby Pmullen503 » Wed Sep 21, 2022 6:42 am
I agree and would add that you won't regret spending the money for a proper crimping tool; the type with dies in the jaws.
Pmullen503
Images: 67
Postby Pmullen503 » Wed Sep 21, 2022 6:43 am
Double post
Pmullen503
Images: 67
