solar disconnect breaker
Postby yycwrangler » Sat Apr 27, 2024 8:34 pm
Hi folks
Looking to install solar on my cargo trailer. I have 4....100watt panels. I have attached the info from the bottom of the panels for reference. I want to put a breaker between the PV's and MPPT. My limited knowledge prevents me making a decision of what size of breaker and I'm hoping someone may be able to help me..Running the 4 panels in series. Thanks in advance
4 Pcs 100 Watt 12 Volt
Monocrystalline Solar Panel
Maximum Power: 100W (each solar panel)
Maximum System Voltage: 600V DC (UL)
Open-Circuit Voltage (Voc): 22.3V
Short-Circuit Current (Isc): 5.86A
Optimum Operating Voltage (Vmp):
18.6V
Optimum Operating Current (Imp):
5.38A
yycwrangler
Re: solar disconnect breaker
Postby Capebuild » Mon May 13, 2024 5:51 am
I looked on my system and I have a 30 amp breaker located in the positive line coming from the panels and in between panels and the Victron MPPT. I have 2 100 watt panels.... so you'd have to do the calculations to see if using 4 100 watt panels might change the breaker size you use.
John
Capebuild
Images: 130
Postby featherliteCT1 » Mon May 13, 2024 5:11 pm
I do not know how you intend to wire your panels.
Solar panels do not need to be fused unless three or more panels are wired in parallel. If so, each panel must be fused just before the combiner box, with each fuse rated at the “Maximum Series Fuse Rating”.
The sticker on the back of the panel should state the “Maximum Series Fuse Rating” for each fuse.
In any event, for convenience, IMHO, a quality DC rated breaker can be installed before the charge controller to serve as a disconnect switch for maintenance purposes, so long as the voltage is relatively low, say 20v or so. Otherwise, a PV disconnect switch should be installed that can handle the voltage.
featherliteCT1
