Converting Portable AC/DC Fan to run on 12V
Postby foxontherun » Fri Jul 19, 2024 9:39 pm
Good evening, I have a portable fan I have been using in my house that I would like to put in my trailer and run off 12v. This fan can run on AC power or you can use six "D" batteries to operate it. The AC Adapter says 9v on it. Would some kind of voltage regulator be needed to run it on 12v like one of these:
https://www.amazon.com/9V-1-7A-DC-DC-Co ... B07QGXL9XP
https://www.amazon.com/DROK-Converter-R ... 20&sr=8-10
My plan is to cut the AC plug end off and wire the power cord up to the DC system. The other end of the AC plug is a Type M barrel end that plugs into the fan. Here is my fan adapter specs:
173764
Thanks,
Harry
foxontherun
Images: 91
Re: Converting Portable AC/DC Fan to run on 12V
Postby Tom&Shelly » Fri Jul 19, 2024 9:42 pm
foxontherun wrote:Good evening, I have a portable fan I have been using in my house that I would like to put in my trailer and run off 12v. This fan can run on AC power or you can use six "D" batteries to operate it. The AC Adapter says 9v on it. Would some kind of voltage regulator be needed to run it on 12v like one of these:
173764
Thanks,
Harry
Yes, either of those should work fine. Their current ratings are both above the 0.7 amps listed on the fan. :thumbsup:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby foxontherun » Fri Jul 19, 2024 9:45 pm
Great! i will get one ordered. Appreciate it!
Harry :thumbsup:
foxontherun
Images: 91
