12 Volt Timer
12 Volt Timer
Postby zapj » Mon Apr 17, 2006 2:33 pm
Has anyone noticed a 12v timer in their travels. I was thinking about one for either an appliance or for a lighting circuit. It may come in handy for turning off the lights if you fall asleep early. ;)
zapj
Images: 40
Postby 48Rob » Mon Apr 17, 2006 5:39 pm
Hi,
There may be a 12 Volt timer available, but a 120 timer will work just as well, and likely be cheaper.
I used a 15 minute timer for my bathroom fan, cost twelve dollars.
There are also 30, and 60 minute timers available.
(The 120 Volt timer doesn't care if you run 12 Volts through it, just don't go the other way).
Rob
48Rob
Postby Rob » Mon Apr 17, 2006 6:35 pm
Rob--
Isnt' it kind of tough to get those two or three prongs of a 120V timer into the cigarette lighter for 12V? :? :lol:
Rob
:wine:
:peace:
Rob
Images: 58
Postby jo_tigger » Mon Apr 17, 2006 7:04 pm
If you just want to turn off lights and appliances a standard windup timer will work. Of course the tick tick tick might keep you up all night. :oops: These timers are hardwired and generally install in a switch box in place of the on/off switch. They are also rated for AC loads so think about what you are attaching. I think they might make some that are quiet. 12 Volt Digital timers will cost considerably more and are mainly used to turn on and off devices.
Richard
Austin, TX
jo_tigger
Postby 48Rob » Mon Apr 17, 2006 7:28 pm
Richard,
You're right, I should have mentioned that they can be noisy...
If you have a tv. or a fan going, you probably won't notice it, but if you're trying to listen to the crickets, it could be bothersome.
Most of these timers are rated at 10-12 Amps for 120 Volt use, so at 12 Volts, will handle a hefty load.
My installation was on an interior hollow wall, the physical size requirements of a box could eat up valuable space in a standard tear...
Thanks for bringing these points to light! :thumbsup:
Rob
48Rob
Postby zapj » Mon Apr 17, 2006 9:56 pm
Thanks for the info. I had thought of the 120v timers but because of size I was wondering about a 12v device. The expense does not justify the occasional need.
zapj
Images: 40
Postby Sonetpro » Mon Apr 17, 2006 10:22 pm
I don't know how you are with electronic's but here is a schematic to make one.
http://www.uoguelph.ca/~antoon/circ/relay11.html
Sonetpro
Images: 107
Postby zapj » Mon Apr 17, 2006 10:36 pm
Hey Sonetpro, thanks for the hieroglyphics. :lol: :lol: With that said your question about my knowledge of electronics has been answered. :? I do have a nephew who dables in such things so I'll pass the schematic to him. Again thank you.
zapj
Images: 40
Postby GeorgeTelford » Tue Apr 18, 2006 3:33 am
Hi Rob
Not strictly true
12 volt DC switches need a a faster switching time than 120 VAC otherwise the contacts are likely to weld ON.
Make sure that any switch you use is rated for DC power as well, it needs a higher spec than AC mains to ensure the contacts dont weld.
GeorgeTelford
Postby 48Rob » Tue Apr 18, 2006 6:41 am
Hi George,
Thanks for the tip. :thumbsup:
I've never had that trouble, but if I do, I'll know why.
Rob
48Rob
Postby Sonetpro » Tue Apr 18, 2006 6:48 am
If you're switching DC it's best to use relays. You could make a circuit that uses AC control to switch a DC relay
Sonetpro
Images: 107
