Basic frame wiring for tail lights to car.
Postby Ron Dickey » Sat Jun 10, 2006 11:52 pm
I am about to attach the wiring.
is there a tester to you know you did right
Voltmeter is one ... what else?
How do you run the wires run it in a tube? tie it to the frame or what?
using a 4 prong but I heard one should attach a seprate wire for brighter trun lights.
what is you view or site that best descibes it.
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby Miriam C. » Sun Jun 11, 2006 12:08 am
Ron
I ran a "Y" wire. It has green/brown on one leg and yellow/brown on the other. They end with a 4 prong connector. I ran the wires down the side channel. (Had I not had channel I would have run them in conduit or pvc.) I connected the side marker lights by tapping in the brown wire on each side with brown wire so the run is still in one piece. You can get clamp on connectors, but I exposed the wire before clamping them so I get a good connection.
Green to right turn and Yellow to left turn, white to ground
If you get a 6 prong you can run back up lights too. ;)
Miriam
