hey george telford
hey george telford
Postby waywardson » Sun Jun 18, 2006 5:26 pm
hey george.
the radio on my boat shuts down when i turn the volume or the base up,
it started doing this last season,
i have turned the base all the way down and was able to increase the volume, (somewhat)
it does this with a fully charged battery,
when i turn the river lights on, (with the motor not running)
the radio will power down, (off)
then it will power back up,
the radio is several (5?) years old and was moderately priced,
i do appreciate your knowledge and will appreciate your advice on how to correct this problem,
thanks,
george / waywardson
waywardson
Postby madjack » Sun Jun 18, 2006 6:48 pm
..and while your waving your wand...I have a 30 yr old stereo...the lights come on but no sound comes out inless I stand on one leg and hop in concentric anti-clockwise circles...think ya can come up witha fix for me... :D :lol: ;)
Postby waywardson » Sun Jun 18, 2006 7:48 pm
hey jack,
why did you post that ?
the problem i described is most likely electrical,
and isnt george the most knowledgeable ?
i have learned a lot from his posts,
i thought he was the boards electrical guru
george / waywardson
waywardson
Postby PaulC » Sun Jun 18, 2006 8:06 pm
George, Sounds like a weak earth to me. The radio in my truck started doing something very similar and I discovered that the earth connection on the amplifier had worked loose. Tightened it up and no more problemo.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Jiminsav » Sun Jun 18, 2006 8:07 pm
George, sounds like a capacitor inside your radio is fubar, if it's worth fixxing, take it to a marine radio shop, but if it's cheaper to buy a new one, i'd go that route.
MadJack, sounds to me like your dilithium crystals are cracked..try spinning on your head and see if that helps. 8)
Jim in Savannah
Jiminsav
Images: 40
Postby PaulC » Sun Jun 18, 2006 8:09 pm
Jiminsav wrote:MadJack, sounds to me like your dilithium crystals are cracked..try spinning on your head and see if that helps. 8)
Now that I'd like to see :lol: :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby GeorgeTelford » Sun Jun 18, 2006 9:13 pm
Could be many things.
Some have been suggested but 2 others come to mind
1. wire guage is too small and voltage drop causes the cut out, this sounds especially reasonable with the running lights effect.
2. Battery is weak (may show fully charged due to surface charge)
GeorgeTelford
Postby Steve_Cox » Sun Jun 18, 2006 9:33 pm
george / waywardson,
I agree in part with George's #1 answer. Voltage drop, do you have any connectors or terminal strips in the 12v + or - wires going to the radio? Sounds to me like you are getting minimal voltage to the radio, and when the load demand is changed for one reason or another it fails to operate. Check wire connections on the positive and negative to the radio would be my 1st look, after that I think it would be time to get out a good multi-meter and look for voltage drop. If you find none, perhaps you have corrosion within the radio itself.
Steve_Cox
Images: 196
Postby madjack » Sun Jun 18, 2006 9:49 pm
...sorry George(wayward) but it is just that electronic gremlins are so hard to fix even with the unit in front of you much less a SWAG based on a basic description of the problem...I just felt that realistically, it was asking anyone a lot to come up with the PROPER diagnosis without the unit in their hands...in other words, I thought that there may have been a posibility that you were putting George(the other one)on...my bad :oops: .............
Postby waywardson » Sun Jun 18, 2006 11:24 pm
not a problem Jack,
but I would appreciate your not confusing me with some of the folks on the board who fail to show respect for knowledge,
heres what i have come up with,
the problem is voltage drop for sure,
i ran new wiring direct from radio to battery with inline fuse,
(bypassing the fuse box)
problem solved,
but i guess i will need to replace the fuse block,
george / waywardson
waywardson
Postby GeorgeTelford » Mon Jun 19, 2006 4:05 am
Hi George
Could you not route the new wire via the old fuse block? check the terminals out and clean up of needed.
GeorgeTelford
