Oni wrote:I have read many good things about this stove: http://www.bushbuddy.ca/
Expensive...and there are plans for home made stoves using some empty cans that use the same principle...but the craftsmanship is supposed to be outstanding on these stoves. Plan to try and make my own...and may buy a bushbuddy as well. Be good for a disaster kit as well as camping.
razorback wrote:xrover
I was intrigued by the kelly kettle and went to their web site. It says to never place the cork or any obstruction over the water pour spout.
they say the cork is only to be used if you are transporting cold water in the kettle. Not trying to be a smart a just wanted to let you know their safety precautions.
# Remove protective cork from kettle and fill kettle with water. Do not replace the cork - the water spout must be free from ALL obstructions when the kettle is in use. (Note: If you do not need to carry water in the kettle, we recommend that the Cork be removed entirely rom the kettle as this will ensure that the kettle is not misused)
# Fill base with combustible material such as newspaper, dry grass or very small tinder. Then place the kettle securely on the base.
# Light fire through the hole(s) in side of the base and face into wind for extra draught if required.
# Insert additional fuel through the chimney (use small twigs or Pine cones for best results).
# When the water boils, hold the handle at a 90° angle to the body of the Kettle – then lift Kettle clear of the base. Use handle and chain for pouring. If additional boiling water is required, simply refill the kettle, place it back on the fire base and refuel the chimney again!
Larry
