PICKING THE BEST CHEST
To be clear ~
What I want in an ice chest ~
Goal:
7 to 10 days no going to the store for ice:
An Ice chest that can be loaded once optimally twice max with a bag of ice
and hold food temps acceptable for 7-10 days. This will allow for the coming
and going to an trailer gathering or Dutch Oven gathering (DOG),without
the usual getting more ice with trips to the store. After all camping should
be camping, not a constant worry about ice or leaving to go to a store.
Given:
Electric or 5 day coolers alone don't give satisfaction for the
small trailer camper who wishes to go and come home with food safe:
1)Electric coolers are not at a efficient state to accommodate small trailer or camping needs.
2) Most standard and so called 5 day ice chests have to be filled with ice
almost every day to keep food safely with peace of mind. There are
exceptions, but most of the time the store see you more than you would like.
My experience:
My 5 day cooler of reasonable price falls short of my goal and ice don't last the 5 days touted:
I have the Igloo MaxCold and am not that impressed with the going to the
store every day to get a bag of ice. My camping experience would be
enhanced if the cooler would stay cool longer and the ice in the cooler
wouldn't melt as fast giving me peace of mind that my food will be ok for
my friends and I when needed.
High tech ice debunked:
Techni ice a flop
Was going to go to the
TECHNI ICE (Thread)
but as proven by
oklahomajewel that
option don't hold cold either.
Ice chests to sort through:(clicky)
* I have only put a few brands of ice chests here.
There are many brands and if you know of a 7 day or better chest let us
know please.
Big Game 60 Qt Chest 9-10 day
DownUnder ice chest:
DownUnder ice chest 48qt uP to 10 days:
DownUnder ice chest 75qt uP to 10 days:
DownUnder ice chest 115qt uP to 10 days:
DownUnder USA 90 Qt. Tropical Cooler uP to 7 days:
Ice Kool Many sizes 3-10 days
Iowa Rotocast Plastics Ice Otter Outdoor 56qt Cooler Can keep ice for over a week:
Iowa Rotocast Plastics Ice Mountaineer Outdoor 70qt Cooler Can keep ice for over a week:
Iowa Rotocast Plastics Ice Outback Outdoor 132qt Cooler Can keep ice for over a week:
Iowa Rotocast Plastics Wolverine Outdoor Cooler 192qt Can keep ice for over a week:
Iowa Rotocast Plastics Ice Grizzly Outdoor 432qt Cooler Can keep ice for over a week:
More useful information:
Off gas water in bottles before freezing for longer freeze (Gary Simmons)
Free ice & ice blanket method (Steve Cox)
Researcher Dispels Myth of Dioxins and Plastic Water Bottles that are frozen
Keeping your coolers cold
Cooler tip guide
Reflectix®
Box Liner
Havin' a party or cookout soon? Did you know Reflectix® Insulation can
double the life of ice in your cooler?
Reflectix® Insulation reflects the sun's heat; therefore it keeps your
refreshments cool in the middle of summer.
Reflextix facts (L@@k under "Retail" for information)
Reflextix info and finding nearest retail outlet:
Just dial
(800) 879-3645 push #1 customer service for technical and installation assistance or e-mail
us at
[email protected].
Reflectix® Retailers:
Lowes, Ace Hardware, Orchards Supply
Reflectix® comes in rolls of 16" 2' and 4' widths:
Dry Ice
Dry Ice facts
Dry Ice side cooler method:
You could do a two-stage arrangement. Kept a dry ice supply separate,
sealed, double insulated, etc. Only a few "blue ice"s shared storage with
the dry ice. As needed, move a really cold blue-ice into a food cooler, and
move a used-up blue ice back into a dry ice cooler. This provides
easily-regulated temperatures for food and drink, and you don't
accidentally freeze your beer.
Maybe the
Techni Ice could be used in this
manner instead of the blue ice, if you already have this product
Ice chest testing for the 5 day type chests:
Tests of 5day chests against each other and more expensive chests
proves more insulation and seal makes the difference:
These are tests by different entities on ice chests.
I have compiled them for ease of decision making.
(Although these 5 day boxes don't meet my goal I have put them here for
those that are less picky than I am for a 7 to 10 day chest.)
Coleman & Igloo (Most common ice chests used by many Reasonable priced)
Coleman Xtreme edged the Igloo MaxCold in a photo finish
Coleman coolers
Coleman helpful Hints for packing and using your cooler
Igloo Coolers
Rubbermaid Coolers
Rubbermaid tips for Coolers
Fridgid Rigid
Frigid chests are more expensive than most but claim 7-10 day ice hold.
Not an option for me but maybe someone else.
Test against Colemen = Fridgid Ridgid wins
Other close subject information:
Keeping your space cool - a short lesson in thermodynamics
Freezer tips: pdf
My Conclusions:
My conclusion is that air getting into your ice chest is most often the
determining factor of temperature control. A chest with the best rubber
seal and snap lock lid with the most insulation seems to be the best type
of ice chest to have. Insulation, coupled with some home remedies of freezing
your own block of ice maybe letting the water set to off load air before
freezing is an option. The use of an ice blanket may keep the air around
the food cold and ice from melting for a longer time between adding ice.
It appears that block ice is the best for extended time coolness as the
density and less surface area would allow for better function. As well as
a block of ice being dense could take up less space. However ice cubes
can fit around objects and mold to the food and Ice chest better. The air
factor is the key here so block ice seems to be the best for longevity.
Dry ice may or may not be used in the cooler. However dry ice in confined
spaces shouldn't be used for health reasons. As well any item touching the
dry ice will freeze. Have heard of a barrier of frozen bottled water between
dry ice and food works well. I Haven't tested dry ice and so more data and
testing is in order.
One more idea is to create your own external temperature reflective shield around
the ice chest for yet one more level of insulation from the heat and the sun.
Another useful adaptation would be to have a basket with handles inside to
be able to lift out the contents with ease, for visual access & ice change.
So here is where I stand at this time.
The cheap ice chests with little insulation and no snap lids are junk. They
are for day use as in beach or tailgating. They should be shunned at all
costs as a space saver and a money hog for bags of ice you will feed them.
A more expensive ice chest than the Coleman Xtreme or the Igloo MaxCold
with more insulation and air tight extremely well sealed openings may be
the choice for some. Or you can try some of the ideas
Steve Cox and Gary
Simmons have put forth in your Coleman Xtreme or the Igloo MaxCold
before you go out to spend more money on an upscale ice chest.
I intend to get an uPscale chest and do all of the above ideas as the 10 day
cooler would reach my goal and with precautions with ice formation, block
ice and ice blankets as well as external layer of insulation, my chances of
being a happy camper who isn't spending money or going to the store for
ice as often and doing what I go camping for seems in my grasp.
Will most likely have a separate drink ice chest as opening and closing the
lid on the main chest expedites heat getting in to do its worst.
May try a third cooler for extended trips to hold dry ice and keep blue ice
cycled into that cooler and out into the main coolers.
I am leaning towards the DownUnder no nonsense chests either:
Seems the Aussies have a way with chests however that Techni Ice came
from there and so would like to get some feedback on these chests
Anyone else have any luck with 7-10 day chests
If so what brands and your testimonial would be appreciated
