Testing the old equipment and trying out new stuff as we get a better idea what we actually want before finding out the hard way out at a campsite.
Pulled out the 413G to try out our new Nordicware "2 burner" size aluminum griddle. That griddle is SOOO NICE to use! Feels like acres of cooking area. The stove on the other hand.. the fuel tank cap was a bit leaky. The old gasket was welded in there from age and I tried a cap from one of the lanterns. It also wasn't a perfect air tight seal, but close enough to be functional. So I had a replacement cap shipped in after this trial run.
Stanley french press: Another new purchase.. Normally I just pack instant coffee packs since it is easy and basically takes up no room. But it does leave some to be desired. My glass french press probably wouldn't hold up too well and it needs a secondary container to warm the water. With the Stanley unit you just pull out all the guts and heat the water in the stainless container. I tested it out on the stove and worked great! I'll just put the coffee in a ziplock bag and pop it inside the container for transit.
