Cellular PVC Panels
Here is a generic building plan for a teardrop designed by the members of T&TTT.
Cellular PVC Panels
Postby rhubbell » Mon Jul 15, 2019 3:54 pm
I am building a "larger" (6 x 12) camper. Wondering if anyone has used cellular PVC sheets for walls, floor or, roof. There are several companies you may have in your area such as Versatex, Veranda, Azek ... The material will not absorb water, i lighter than plywood, and is UV stable. Only two issues I can see is the price and expands more (10%? ) more than plywood. I know boat builders us something similar but even more expensive. I appreciate any feedback.
Rick
rhubbell
Re: Cellular PVC Panels
Postby greygoos » Mon Jul 15, 2019 8:15 pm
Watch out for expansion and contraction.
greygoos
Postby rhubbell » Wed Jul 17, 2019 2:04 pm
The only information I could find was about 10% greater linear coefficient of thermal expansion. Any experience with the product as to how much expansion/contraction for construction purposes?
rhubbell
Postby greygoos » Wed Jul 17, 2019 4:28 pm
I have used PVC dimensional lumber as drip rails and installed with SS fasteners. The boat builders use StarBoard which is quite expensive. I have used it as a sort of chair rail in food trailers. I personally dont believe that it is as solid as wood or metal, it flexes quite easily but it pays to experiment. I am still contemplating using ABS over foam for my next build.
greygoos
Return to Generic Building Plans
