- img012.jpg (224.95 KiB) Viewed 633 times
Hi All, I am in the middle of designing my next TD and wanted some more info on tongue design and here is what I found. As the angle increases the strength decreases (tension) by a factor of "K". The pointier the higher tension strength. Because of the nature of the load tension is not as useful as yield strength but the "K" factor doesn't change according to a mechanical engineer I chatted up.
The tensile strength of A36 steel is 60K-80K psi and the yield strength is 36K psi. I use the safety factor of 2 but some prefer 1.5.
