Lights on a HF 4x8 Trailer problem
Postby The Ruckus » Mon Dec 22, 2014 4:16 pm
I just assembled my HF 4x8 Trailer and added the lights matching color to color. Easy, or so I thought.
Connected the 4 pin to my Ford explorer with proper tow connector (color wires matching)
All lights work correctly until I hit the brakes.
They don't work, plus if I have the signal on, it goes off too.
Checked all the color matching connection and all are good.
Any Ideas?
I have a DMV appointment in 2 hrs...
Steve "The Ruckus" Whelan
The Ruckus
Re: Lights on a HF 4x8 Trailer problem
Postby KCStudly » Mon Dec 22, 2014 11:36 pm
Probably a grounding issue.
Postby The Ruckus » Tue Dec 23, 2014 1:01 am
After hours of messing around scratching paint to get grounds, I finally run a straight line from the rear lights to the neg on the battery. The lights worked. Missed my appointment though...
The Ruckus
Postby Redneck Teepee » Tue Dec 23, 2014 7:07 am
The Ruckus wrote:After hours of messing around scratching paint to get grounds, I finally run a straight line from the rear lights to the neg on the battery. The lights worked. Missed my appointment though...
90% of all electrical problems are ground issues on trailers. Sounds like you discovered and solved it though, good luck at the DMV. :thumbsup:
Redneck Teepee
Images: 21
