lcurrie wrote:Wow. Even more great info!
#1Do you guys think it's possible to put a platform on the front for one scooter and a
hitch platform on the back for the other without doing any mods to the trailer?
#2Would the extension of the toungue be for weight distribution or to add lengthen the tongue for a turning radius?
#1 ...you would still have to add the additional crossmember to counter the twisting stress we discussed earlier...
#2 ...essentially both but but primarily for the extra distance for turning....
...the following comment is not aimed at anyone or a knock on anyone...it is just a personal rant........
...personally , I would not use one of these types of trailers for anything but hauling trash to the dump or firewood/building materials home...primarily, that is all they were designed for...you pay in the neighborhood of 300 bucks for one and then haveta modify it...I just bought a #9 Torqflex and the steel for my new build(a 5x8) for 295 bucks, I realize I still have wheels/tires to add to this BUT I will end up with a trailer that is several magnitudes better that any HF or Red or TSC trailer...I further realize that not everyone has the same set of skills but once again I say that if you can cut and fit wood, you can cut and fit steel and even if you don't weld, don't have a friend with welding skills, you can still pickup the yellow pages and hire a weldor to come to your house, with his truck mounted rig to do the welding after you have done the fit up..
...once again, this not meant to knock anyone who has used one of these trailers...there are a kazillion wonderful little campers out there that have used one as a base...this is simply a personal thing with me...
Lynn, if you don't wanna do the mods to make the trailer properly useful(and safe), then just leave the scoots at home and go enjoy your camper in the great outdoors and I hope you will forgive me my little rant.....
