Section 8 wrote:I will have to call Dexter and figuer out weather or not the larger brakes can be fitted to the smaler axle (since they don't specify either in the catolog, I would guess against it).
brian_bp wrote:The Torflex problem in multiple-axle installations is that they - unlike leaf-spring systems with equalizer links - don't share load between the axles nicely. As a result, each axle needs to be over-spec'd to handle more than its usual share over bumps, and the load-to-capacity thing become an issue
There's no load-sharing issue in a single axle trailer. Rubber or steel leaf, you still want the springs reasonably well matched to the load
brian_bp wrote:I would be very surprised if the Jeep owner's manual allowed more than 1000 lb of trailer weight without trailer brakes. Sure, there's lots of engine braking, and engine braking is good to limit speed on descents, but that's not how you stop when you really need to. Doing all of the braking for over 1000 lb of trailer is a big deal to a vehicle the size of a Wrangler. You'll only find out how big a deal if you really test it, which could be a fatal experiment.
Section 8 wrote:brian_bp wrote:I would be very surprised if the Jeep owner's manual allowed more than 1000 lb of trailer weight without trailer brakes. Sure, there's lots of engine braking, and engine braking is good to limit speed on descents, but that's not how you stop when you really need to. Doing all of the braking for over 1000 lb of trailer is a big deal to a vehicle the size of a Wrangler. You'll only find out how big a deal if you really test it, which could be a fatal experiment.
As in the post, its an unlimited, which is 3,500 lb towing capacity.
If the trailer/load exceeds 1,000 pounds, the trailer should have its own brake system
