We want to make sure that it can get out of the garage. After that . . .
Wos wrote: Most of the expanding foams soak up water like a sponge, .
Boodro wrote:I had a friend with a boat trailer that was tubing . He sealed the ends with caps & installed an air valve on one end & filled the frame with nitrogen. he checked his pressure once in a while to makes sure there were no leaks , it worked great. Never had a rust problem. Just more ingenuity for ya!![]()
Muggnz wrote:Will any these expanding foam type of products cope with the constant vibrations a TD will subject them to? Without failing, due to disintergration or worse.
