Hello Everyone,
I have an idea that I wanted to get some feedback on.
I was wondering would it be beneficial to most all T&TTT ers if there was a main frame kit available for the do-it-yourselfer?
I would think that if a kit could be developed that would remove any welding and be designed with some specific features that could make the rest of the build a little easier, possibly more T&TTT ers would tackle a home build. I see that there are some ready made kits, like from harbor freight, but do they really fit the bill?
If we were to design most of the parts out of and aluminized 12g steel it would add additional corrosion protection and wouldn't necessarily need to be painted. This would give an opportunity to design the outer rails pretty much any way you want. I would still use some lightweight tubing for the tongue but the sheet metal outer rails and cross members would be strong and lightweight.
I would also consider adding a dexter torflex axle as well as coupler and hitch jack. I receive shipments from my supplier every other week and am convinced I could get a really good price on these parts.
So, if any of you think that this is a good idea, before I proceed, I would like your feed-back on a few key questions:
1) Is it a good idea?
2) What size should the main body be. Maybe we could have a few different sizes.
3) What would the average trailer weigh and what is your average cargo weight. Most of this will answer the next question.
4) What type of tires and wheels do most of you like to run? This question is mainly about wheel bolt pattern. Is there a preference?
5) Where is the best place to set the axle? It is common in the trailer industry to set the axle center line back 1" for every foot of trailer length. So an 8 foot trailer would have an axle set 8" back from the center of the main trailer box. Meaning, don't count the hitch. It looks to me as though most T&TTT's have there axles set a bit farther than this.
If we do this I would like it to be a group effort. I have the means to design and produce it, but I would like everyone's feed-back to narrow down the options. Obviously this will keep the cost to a bare minimum. I would also consider a proto-type for free or a very low cost so that someone could give the first one a real world try. My engineers have the means to display prints and plans on-line, so during the design phase, everyone could get a say.
Thanks for your time.
Just trying to give a little something back to the trailer industry.
PS. I wonder if this should be posted in the general construction section as well?
