square tubing axle
square tubing axle
Postby BigDaddyCool » Tue Feb 26, 2008 8:55 pm
do i need this with a square tube? or just drill a hole in the tube?
BigDaddyCool
Postby G-force » Tue Feb 26, 2008 9:23 pm
A flat plate with a hole should be welded on to locate the axle on the springs. The one you have pictured has the sides bent down and radiused for a round tube, the ones for a square tube are just rectangular and flat with a center hole.
Mike
G-force
Images: 22
Postby Nitetimes » Tue Feb 26, 2008 9:41 pm
If you don't need the extra spacer just drill a hole in it, a lot of them come that way.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby BigDaddyCool » Tue Feb 26, 2008 10:03 pm
thank you :D
BigDaddyCool
Postby Alphacarina » Wed Feb 27, 2008 12:38 pm
I would weld the plate on - You would be drilling a fairly large hole exactly where you don 't want it for strength purposes, plus it will allow moisture inside the axle which will eventually rust it out from the inside out . . . . you'll get no warning when one wheel is about to fall off
Don
Alphacarina
Postby Nitetimes » Wed Feb 27, 2008 5:16 pm
Alphacarina wrote:I would weld the plate on - You would be drilling a fairly large hole exactly where you don 't want it for strength purposes, plus it will allow moisture inside the axle which will eventually rust it out from the inside out . . . . you'll get no warning when one wheel is about to fall off
Don
Never seen it happen. Axles are thick enough that the hole isn't an issue.
I've changed them for a lot of reasons but never that.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby BigDaddyCool » Wed Feb 27, 2008 6:24 pm
drilling one or two holes would be good for air circulation and removing condensation...
making a frame in tubing with no holes for moisture to escape will actually promote rust.
by the way i'm welder/fabricator :thumbsup:
BigDaddyCool
Postby Alphacarina » Wed Feb 27, 2008 8:00 pm
News to me
I have 6 different trailers of all descriptions here on the property - About the only single thing they all have in common is there are no holes in any of the 10 factory built axles
Don
Alphacarina
I agree with Don
Postby eamarquardt » Wed Feb 27, 2008 8:46 pm
For what it's worth, I agree with Don.
Cheers,
Gus
eamarquardt
Images: 150
Postby Nitetimes » Thu Feb 28, 2008 12:22 am
I designed, built and repaired trailers of all sizes for over 15 years, so you've obviously seen more than I have.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby brian_bp » Thu Feb 28, 2008 3:49 pm
Closed tubes with moisture in them can rust out. Closed tubes which are clean and dry inside stay that way, and seem to me to be unlikely to rust.
My guess is that factory-built axles with closed tubes are decently dry when built, so no hole for drainage is needed. Add a hole on top, and you may change that.
Personally, without the benefit of any specific experience or authoritative references, I would want the plate added; however, I can certainly believe that many just have a hole drilled in them.
brian_bp
Images: 9
Postby BigDaddyCool » Sat Mar 01, 2008 1:39 am
where i work we always drilled holes in tube, post ets...
aluminum or steel
because of condensation, hot and cold will make moisture in enclosed tubing...
and we build 45' Dump Trailer , flatbed, transfer, logging etc about 6000 a year..
we have seen so much water in bumper that when it froze the bumper craked,
thats why they drill holes in them, waranty issue
rust takes alot of year to go thrue steel anyway
BigDaddyCool
Postby Alphacarina » Sun Mar 02, 2008 4:06 pm
BigDaddyCool wrote:because of condensation, hot and cold will make moisture in enclosed tubing...
Not possible - If there isn't any humidity already trapped in the sealed tube, then you can't condense any in there . . . . it's sealed
You never picked up a 'message in a bottle' on the seashore? The paper inside is dry ;)
Don
Alphacarina
Postby BigDaddyCool » Sun Mar 02, 2008 5:46 pm
Don[/quote]
it make sense, either way i dont think its a big problem.
Happy teardroping ;)
BigDaddyCool
