The warm weather has brought me out of hibernation (unheated garage)and I'm resuming work on the TD. The floor will be the first order of business, which brings me to today's questions:
Q: How best to attach the floor to a tube steel frame?
Q: Do I need to take any measures (e.g., a gasket or a dollop of construction adhesive or caulk at each screw/bolt) to prevent water intrusion through the screw/bolt holes into the tubing or the floor?"
Background/Details:
The frame is a Magneta 6x8 bolt-together utility trailer kit. What makes it slightly unusual is that it designed to take a recessed deck, made with a 4x8 and a 2x8 sheet of ply, that fits flush with the frame. The frame is 2" square tubing and is made 4" oversize to form a 6x8 well to receive the deck. The 3 inner crosspieces are smaller dimension tubing dropped 3/4" to provide the clearance, and the insides of the ends have strips of angle welded 3/4" down to support the ends of the deck.
The floor will sit on top of the frame, rather than drop in like the deck. It will be constructed as in the Generic Benroy (plywood top over a 1x2 frame, with foam insulation and asphault sealant). To accomodate the recessed well, I plan on making the inner cross pieces deeper so that they reach down to the tubing crosspieces.
Bolting it to a channel frame would be straightforward, but a thru-bolt on a tube frame would risk crushing the tube. The shop manuals I have are silent on the matter. Would self-tapping or deck screws be the answer? What advice to you have, Master Yoda?
