Wheel Spacers
Wheel Spacers
Postby dan galvin » Wed Apr 22, 2009 8:38 pm
I know what i need but cannot find it if i needed it for a car no trouble at all i am looking for spacers for a 4 hole 4 in bolt circle 10 in rim with a 20.5x8.0-10 tire
can someone point me in the right direction
thanks Dan :worship:
dan galvin
Images: 43
Postby TPMcGinty » Thu Apr 23, 2009 5:55 am
Tim
TPMcGinty
Images: 146
Postby Endo » Thu Apr 23, 2009 3:02 pm
Or maybe a 4 lug to 4 lug adapter??
http://adaptitusa.com/index.asp
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby angib » Thu Apr 23, 2009 5:03 pm
Dan, I'm sorry to be the bearer of bad news a second time, but if you're using the spacers to push the wide wheels out from a HF trailer, then that means you'll be moving the centreline of the wheel out from the hub. That makes an overhang that will put a bigger load on the bearings.
I doubt there would be any problem if, say, you had the 1800lb capacity trailer and only had 1000lb of trailer added to it. But if you've got the 970lb trailer and you're planning to load it right up to its limit, then the bearings could have a short life.
I don't think they would fail catastrophically, so you could just take the view that you'll replace the bearings when/if they get noisy and/or sloppy - but that could be every year in the worst case.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby dan galvin » Thu Apr 23, 2009 9:33 pm
thanks all i got what i needed from ezaccessory i have a good trailer frame & axel from my old popup i just built a little to wide about an inch
so i am going to deal with the bearings if they become trouble
thanks again
Dan :thumbsup: :applause:
Andrew Iwas looking through your album Thanks i needed the dementions for putting my gas struts on my hatch and there they were
Thanks again Dan :thumbsup:
dan galvin
Images: 43
