Hello, all!
I just purchased a very small teardrop trailer that was made on a tiny trailer frame. The unit weighs just under 400 lbs. but the part that I'm unsure about is that the front of the trailer forms a triangle and the ball connector is right in that point of the triangle with no straight shaft for a tongue that I'm accustomed to trailers having. I guess that wouldn't be so bad, but the front curve of the teardrop is less only about 16" behind that connection point. It appears to me that it could cause some real problems if the vehicle doing the towing ever had to cut it really short while backing up or maybe even going forward. I feel like the cabin of the trailer is going to connect with my vehicle. Of course, I only towed it about home (about ten miles) and I was traveling very cautiously since my ball was 1/8" smaller than was called for and I didn't have any lights hooked up.
I am thinking about installing a 2" square shaft extending from the present front of the trailer but would like some input as to what length would be 'ideal' from the front of the curve of the teardrop. I'm thinking one of these should reduce any chance of having that problem, but I don't want to create more problems that I may not even be aware of? (18", 24", 36" 48") There must be somebody out there with some experience at figuring out such things. (Or does it depend upon how far back my axle sits?. I'm a real rookie when it comes to trailer dynamics and parameters.)
Thanks for any knowledge you can provide.
