weight on hitch?
weight on hitch?
Postby yuskis1 » Mon Jul 13, 2009 5:21 pm
how do u figure out how much weight should be on the hitch? im trying to figure out how to balance out my trailer but not sure where to place the wheels. im using the trailer balance spreadsheet to help but just dont konw what my goal numbers should be for weights. pls help!
yuskis1
Postby teardrop_focus » Mon Jul 13, 2009 6:41 pm
Hey. How're you doin'. Welcome to the forum. :-)~
You want between 10% and 15% of your trailer's total weight on the tongue (hitch).
If your tug is a compact car and therefore more softly sprung, use 10%-12%. If towing your trailer with a larger sport utility or large pickup, you can lean more towards 15%.
Say you have a 1000-pound teardrop (that's fully-loaded, ready to go) and are towing it with a Honda Accord or PT Cruiser. Try to keep the tongue weight to 100 - 120 lbs.
teardrop_focus
Images: 127
Postby sdtripper2 » Mon Jul 13, 2009 7:16 pm
Trailer Tongue Weight
Andrew's Trailer Balance Spreadsheet Formula
http://www.angib.pwp.blueyonder.co.uk/t ... tear81.htm
My correlation of data used to plan a trailer build ~ Read from the top
http://tnttt.com/viewtopic.php?t=11178
Here is a rudimentary way of measuring Tongue Weight
Here is another suggestion on measuring Tongue Weight
sdtripper2
Search Garoux
Images: 168
Postby teardrop_focus » Mon Jul 13, 2009 11:54 pm
^ Image
Steve is the man... :applause:
I'm glad to see charts indicating just 10% tongue weight... I think the 15% too high/too heavy for some tugs.
I understand that in Yurp (Europe) they use 8% tongue weight. That's what I'll really be shooting for come tug time.
teardrop_focus
Images: 127
Postby Gerdo » Tue Jul 14, 2009 9:57 am
With all that said...
If you have too much tongue weight on a light vehicle it will squat the rear of the tow vehicle but worse than that it will unload the front wheels causing light steering and loss of control.
Too light of tongue weight and the trailer will have a tendency to fishtail.
Gerdo
Images: 156
Postby angib » Tue Jul 14, 2009 10:46 am
teardrop_focus wrote:I understand that in Yurp (Europe) they use 8% tongue weight. That's what I'll really be shooting for come tug time.
But remember that us Yurpeens (mostly) tow at lower-than-normal speeds - a 50mph or 60mph towing limit is usual .vs, 70mph not towing - plus we expect to be nearer the onset of sway than Merkans.
But then 8% is the top end of the scale for Yurpeen hitch weights - as low as 4% is quite common.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby teardrop_focus » Tue Jul 14, 2009 11:50 am
angib
But remember that us Yurpeens (mostly) tow at lower-than-normal speeds - a 50mph or 60mph towing limit is usual .vs, 70mph not towing...
In most states here the U.S.; specifically here in California the towing speed limit is 55 MPH versus everyone else doing 80+. I've seen large, lifted, privately-owned 3/4 ton Chevrolet and Ford pickup trucks hauling boats or other personal watercraft, motorcycles, etc at 70+. That doesn't mean, of course, that I recommend it.
:R
I plan to haul my tear at 60... which is 5 over posted and is informally allowed (for lack of a better way of saying it).
The bulk of European drivers are certainly more focused on the job at hand than most Americans, that's for sure.
:lol:
And in most cases, that's not a laughing matter. :-\
teardrop_focus
Images: 127
Axle set back percentage.
Postby Wild Bill » Sun Aug 09, 2009 9:50 am
I am building on a boat trailer and can still unbolt the u bolts and slide the axle forward or back. I have a trailer that from the hitch ball to the rear bumper is 20' long. I plan to have a long tongue to have propane, a truck tool storage box and battery. the bed will be in the front ahead of the axle. Still flexable on that. The box itself will be 14' long including the galley in the rear. Finally my question. when you measure for the % I assume you measure from the ball hitch to the tail, not the box size. Or are you caluclating the area just over the box itself??? I have the axle set at 32%. When it was a boat it had a very large motor hanging on the tail and the axle was way back. I want to get this set so I can move forward. Bill
Beavers are Naughty!
Wild Bill
Images: 63
Postby Creamcracker » Sun Aug 09, 2009 10:59 am
Andrew
As a native Welshman now living in the US my trailer ended up with a total weight of 720lbs and atongue weight of 60lbs....I think that's about as closeto 8% as I could have got. Some things you just got to do the Yurpean way!
Philip
Creamcracker
Teardrop Graduate
Images: 142
