Brake rotor warping/judder in the Tow Vehicle
Postby bytehoven » Fri Nov 13, 2009 8:33 pm
One other suggestion...
Proper torque needs to be applied evenly to the lugs. Over torquing or uneven torquing of the lugs is a quick way to warp a rotor.
This is even more important as you move to smaller wheel sizes.
My wife's Mazda CX-9 front rotors were instantly damaged when they were over torqued by a mechanic too lazy to switch to the proper stick. They ended up installing (4) new rotors free of charge.
Always insist on a mechanic using the properly rated torq stick and then re-torque the lugs yourself as soon as possible. Better yet is to ask them to do the final torque with a wrench.
Also, you should know your lug torque specs and make sure they know.
bytehoven
Postby Mini Renegade » Sat Nov 21, 2009 11:49 am
I deal with a lot of brake judder problems working for BMW. The majority are automatic gearboxes. The drivers are braking from motorway speeds to a halt then holding the vehicle with the brake pedal and not the park brake. The area of the disc still in the caliper/pad area doesn`t cool as fast as the exposed disc causing it to warp.
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
