hugh wrote:So, in essence is it adviseable to move the spring perches 9" inboard on each side?
angib wrote:hugh wrote:So, in essence is it adviseable to move the spring perches 9" inboard on each side?
Not if you want to retain the strength of the axle.![]()
Moving the spring perches that much will effectively turn the 3500lb axle into a 1500lb axle, so that's less than you've got now. Everything else will be extra beefy, but the axle tube itself will be weaker than what you have now.
Andrew
