Rebuild of a 46 kit axle
Postby maud'Dib » Fri Jun 11, 2010 3:39 pm
Originally I was hoping to reuse the axle that came off of my 46 kit but after putting the tires under weight last week there was enough slop in it that it caused the inside top edge of the tire to rub the camper sides. I even tried some washer to push the tires out but that didn't help either. So I was going to scrap the original axle and go with a dexter torsion flex axle but after much communication between them and I we determined that their axle would not work with my wheels and fenders. So I was back to square one. Next option was the stub axles, so I called George at teardrop fix it shop and he mentioned that I may be able to replace the bushing/bearing that inside the tubes of the axles. So after that phone call my goal was to tear the original apart and figure out how it worked and how to fix mine.
This is what we are dealing with. This axle is made up of two seperate torsion tubes that are welded together.
I was going to have to cut the end caps off of the tubes but to get access to the caps I first had to seperate the two tubes. I used a grinder and cut all the welds, being careful not to damage the tubes themself. As a side note you'll notice the grease zerk next to another weld. It turns out the weld is just covering up the original grease zerk location. It turns out that that zerk corresponded to a grease channel cut in the shaft bearing inside the tube. A previous owner unknowingly moved the zerk away form the grease channel which may have contributed to the severe wear in the axle.
Once seperated I used the same angle head grinder to cut the end caps off, kind of like opening a tin can. I was attempting to cut through the pipe only, and keep the center shaft/nub intact.
This is what they looked like when I started.
Once the pipe was cut all the way around and cleaned up one tap with a sledge and out popped the torsion shaft. I had no idea what to expect. I thought there would be some springs or some rubber bearings inside but to my amazement it was just a shaft. The shaft provides all the flex for this axle. It has what looks like a stainless bearing/bushing at the swing arm end and two inch slug welded to the other end. That slug end is welded to the pipe creating the end cap that I cut out.
Once cleaned up you could see that the SS bearing/bushing on the torsion shaft had a little bit of wear on the superior aspect, but it wasn't that bad. The side to side measurement of the bearing was something like1.789 and the top to bottom was something like 1.749. But the section of the tube that corresponded to the wear in the bearing showed severe wear. The thickness of the tube wall is around 3/8 inch and about 1/4 inch of that was gone.
So I had two problems. Problem one was the bearing wear and problem two the outer tube wear. To solve problem number two I just flipped the tubes around end to end because the end that had the cap cut out was in original condition. It took a little work with a round file to clean out all the rust, but the bearing on the torsion shaft fit great. As far as solving problem one, the only way to correct that would be having a new one machined and that sounded like a lot of work. So I simply switched torsion shafts from right side to left and left to right. This caused a rotation of the shaft bearing some 110 degrees moving the wore portion of the bearing from the top of the axle to a more rear facing position. After getting everything slid back together It was just a matter of welding it back up. The below pic shows the finish axle along with a wooden form I made that had the bracket locations and the swing arm locations set at the 35 degrees. The form was make prior to taking the axle apart. It made putting it back together a no brainer. The axle seems to be solid as a rock with little to no slop now. Kept the axle original and saved the cost of a new one. The whole project took about 4 hrs, and required a grinder, a round file and a friend with a welder. Hope this can help someone someday.
maud'Dib
Images: 71
Postby teardrop_focus » Fri Jun 11, 2010 4:43 pm
So I had two problems. Problem one was the bearing wear and problem two the outer tube wear. To solve problem number two I just flipped the tubes around end to end because the end that had the cap cut out was in original condition. It took a little work with a round file to clean out all the rust, but the bearing on the torsion shaft fit great. As far as solving problem one, the only way to correct that would be having a new one machined and that sounded like a lot of work. So I simply switched torsion shafts from right side to left and left to right. This caused a rotation of the shaft bearing some 110 degrees moving the worn portion of the bearing from the top of the axle to a more rear facing position.
:applause: :thumbsup:
teardrop_focus
Images: 127
Re: Rebuild of a 46 kit axle
Postby angib » Sat Jun 12, 2010 9:24 am
maud'Dib wrote:The below pic shows the finish axle along with a wooden form I made that had the bracket locations and the swing arm locations set at the 35 degrees. The form was make prior to taking the axle apart. It made putting it back together a no brainer.
Heck, you could have written that at the start - all the way through as I read, I was thinking "how is he going to get the angles right again".....
Sorry, for that lack of trust. :oops:
Andrew
angib
5000 Club
5000 Club
Images: 231
