Northern 5x8 mounting springs
Postby gulfcoast21 » Thu Sep 13, 2012 7:43 pm
My question is..can you reverse mount the springs on an axle. This would put the axle on top of the lower springs with the u-bolts reversed.
My reason for wanting to do this is to lower the deck height on the trailer. I would like to build a teardrop with as much height inside as possible and still get it to clear the garage door?
I asked this question to Northern and the answer I got was that it would void the warranty but not reason why it could not be done.
Thanks
When I ask a question and you think 'well that was an ignorant question', your right. If I was not ignorant, I would not be asking questions.
gulfcoast21
Re: Northern 5x8 mounting springs
Postby Dale M. » Fri Sep 14, 2012 6:44 am
gulfcoast21 wrote:..... I asked this question to Northern and the answer I got was that it would void the warranty but not reason why it could not be done.
Thanks
Do not see any reason why not either and long as axle does not bump frame when suspension is compresses all the way....
Dale
Dale M.
Images: 18
Postby gulfcoast21 » Fri Sep 14, 2012 7:05 am
Thanks....that was my thinking exactly. The wife is just under 5'4". If I can bulid one where she can stand up we will all be happy. She has some problems from a head on collision back in 2000 that still causes her problems.
Thanks
gulfcoast21
Postby unclehickory » Fri Sep 14, 2012 7:51 am
I just did that very same thing on that very same trailer. I think it looks so much better. Matches the ride height of my Impala and is easier for my wife to exit. I have already road tested it and there is no change in how it pulls. I had a 53 Chev pickup with the rear differential mounted the same way.
unclehickory
Postby gulfcoast21 » Fri Sep 14, 2012 9:25 am
Thanks...I was hoping to hear from someone who had already tried it. Off hand do you know how much it lowers the deck?
gulfcoast21
Postby unclehickory » Fri Sep 14, 2012 9:36 pm
It is approximately 3 inches but gives it a great look. It looks much more custom and less like it came out of a box.
unclehickory
Postby gulfcoast21 » Sat Sep 15, 2012 4:11 pm
Thanks for the reply with additional info.
gulfcoast21
Postby bigblockbarry » Sun Sep 16, 2012 6:49 pm
Check your axle to see if it is cambered before turning it over. I did the same thing and my wheels tipped in towards the body. Bought another set of spring pads at TSC and welded them on the opposite side to correct this.
bigblockbarry
