Benroy Classic - Trailer Width Shortening?
Postby Pierre » Tue Mar 28, 2006 1:39 pm
Hi All
I am still going over and over the planning stages of building a Benroy Generic, and noticed that the plans say that you reduce the width of the trailer to 58 1/2". What will happen if I just keep my red trailer 5x8 and make the 1 1/2" adjustment on the width. Why do you narrow the width?
Pierre
"A silly question is one that is not asked"
" A silly question is one not asked"
Pierre
Re: Benroy Classic - Trailer Width Shortening?
Postby rampage » Tue Mar 28, 2006 2:03 pm
Pierre wrote:Hi All
Pierre
Pierre,
The generic Benroy plans call for shotening the width so that the sides of the trailer will be covered by the outer layer of the wall. I'm building the Generic on a Redtrailer but I didnt take anything off of the width. I'm building it on top of the trailer.
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
RED TRAILER WIDTH ISSUE
Postby Pierre » Tue Mar 28, 2006 2:36 pm
Thanks a million for the advice rampage.
Keep us posted on how your plans are working out
Pierre
"A silly question is one not asked"
Pierre
Postby mikeschn » Tue Mar 28, 2006 2:46 pm
Pierre wrote:Hi All
Pierre
The width was narrowed so that it could be covered in baltic birch plywood, which comes in 5' wide sheets.
Of course, if you are using luan, you can make it any width you want.
And if you are building on top of the chassis, you can leave the trailer stock also!
TRAILER STOCK
Postby Pierre » Tue Mar 28, 2006 3:37 pm
Mike
What is the trailer stock that you are referring to?
:o
Pierre
Pierre
Re: TRAILER STOCK
Postby mikeschn » Tue Mar 28, 2006 3:44 pm
Actually I am refering to a stock trailer, as in "unmodified" trailer.
Pierre wrote:Mike
:o
Pierre
TRAILER STOCK
Postby Pierre » Tue Mar 28, 2006 4:02 pm
Thanks Mike
Being a South African living in the USA, I have to get used to the terminology. Thanks again for your help.
Pierre
Pierre
Postby bledsoe3 » Wed Mar 29, 2006 1:16 am
I built my trailer 5' wide and put the sides over the frame.
As Mike said, I used luan so the extra width was not a problem.
bledsoe3
Images: 112
Postby Pierre » Sat Apr 01, 2006 4:56 pm
Thanks for all the help, now to buy a red trailer, this month.
Take it easy
Pierre
Pierre
