http://www.kasperwing.com/Trailer%20wiring.htm
If the springs are maxed out is the correct fix heavy duty springs or would it make more scense to add airbags for suspension?
Regards
Chris
asianflava wrote:Kinda hard to tell with the wide angle lens but, I'd say that they are shot. Judging by the amount of travel you have left, it looks like those U-bolts will hammer the frame since there is no bump stop. Are there marks on the frame? If there are, then it is a good indicator that the springs are bottoming out.
An air bag suspension would be cool, but it will add a lot of comlexity and expense. Buying replacement springs would solve the problem at a reasonable price.
Boodro wrote:Ska, maybe you can add a couple of shocks mounted to the frame & axle ? If the springs are a little weak , shocks should help. Shocks are probably cheaper than new springs. Just a thoiught. Good luck!![]()
