BobR wrote:The problem with reducing tire pressure is two fold. One, the reduction in stiffness of the sidewall reduces the load capacity of the tire. Two, it makes the tire run hotter from increased friction at the footprint and the flexing of the sidewall. If you want to know what this can cause, just search for Ford Explorer and Firestone tire roll-over accidents. Tires that are run at highway speeds need to be properly inflated, period.
The best way to address the bounce issue is to make sure that the sring rate is appropriate for the weight of the trailer and to add shock absorbers to reduce spring rebound.
Just my two cents worth...
I finally checked at work on our Suburban, since I knew it had load dependant tire pressures. For max load it wants 44/80 psi (front/rear), but for 3 people and 200lbs load it goes to 44/50 psi. So there's an example of lowering pressure to get a better ride. It actually mentions the ride comfort on the tire inflation sticker. Since the trailer doesn't need all of the tire load capacity, I don't think a reduction in capacity will be a problem.
If I remember correctly, the Explorer rollover problem was that with higher pressures, the Explorer would tend to roll over during cornering. Ford lowered the pressure (26psi?) to increase road adhesion, but that brought to light manufacturing problems with the tires resulting in blowouts. Jacked up tall vehicles being driven like cars is a bad design.
The increase in heating from tire flex might also be debateable. I don't think there will be much difference in sidewall flex between full pressure/highly loaded tires and lowered pressure/lightly loaded tires. If you compare the sidewall flex for a lightly loaded trailer, then lower psi will result in more flex, but I don't think it will be excesive. (as Nitetimes said, it they're hot, you let out too much air)
Shocks are nice, but they only stop the second bounce. I'll probably add some to my trailer when I'm completely finished, but I'm in the same boat as far as too strong of springs. I have 2 leaf 1250# springs, and I've been thinking of taking out the 2nd leaf. (950lbs trailer weight)
Hope this isn't beating a dead horse, but I finally remembered to check the Suburban...
![Very Happy :D](./images/smilies/econ_goldtooth.gif)
