TS Trailer Tongue
Postby Dooner » Sat Mar 03, 2007 8:13 pm
Sdtripper,
The links you show do not go to the same trailer that you pictured in your first post. My trailer is like the first post picture. The links show trailers with sides and expanded metal floors on them. They are rated at 2000 lbs GVWR, but the no floor trailer is just 1500 lbs GVWR and a GAWR of 2000 lbs.
I think Rich (Nitetimes) is on to it. I was using the wrong wording I guess. It flexes. There is nothing broken. That was the first thing I checked. I think if they would have put two bolts through the back mount, it wouldn't be as bad. The angle is kind of twisting.
So Rich, if I do as I originally thought, by putting a 1" or 1.25" square tube across the trailer above the cross member and in between the floor sandwiching (that sounds funny). I can bolt the tube and cross member together to reinforce the cross member. Am I thinking right?
Maybe I will go ahead and weld the tongue to the mounts instead of bolting.
Thanks guys.
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby dewayne » Sat Mar 03, 2007 9:26 pm
Dooner look in my albun and you can see what I done to my trailer which is the same one you have.
Mine was ok. I A framed it cause I just don't like a straight tounge, and I'm going to mount my battery and possible gas bottle also.
I am going to lengthen the tounge about 18".
dewayne
Pay it forward and the world would be a better place.
dewayne
Images: 25
Postby sdtripper2 » Sat Mar 03, 2007 9:43 pm
Anyone who has bought the TS trailer can you share the website that they used to
get the 1,500 lb unit? The model number that was given would be nice?
Evidently the TS and Carry-On sites don't show a 1,500 lb unit that I can find.
Seems the TS website only shows 2,000 lb units and so how or where did you
get the 1,500 lb units?
Would like to uP date the forum information and so thank you for any help
you can give me. Want to give out the right data.
sdtripper2
Search Garoux
Images: 168
Postby Dooner » Sun Mar 04, 2007 12:57 am
Sdtripper2,
This is what I have.
4x8 no floor trailer
Sku #1000215
Model #4X8NF
Mfg. Carry-on trailer corp.
GVWR- 1500 lbs
GAWR- 2000 lbs
Tires- 480 x 12C
Rims- 12X4JA
90 psi
Single Axle
And I just saw it at my local Tractor Supply.
Dooner.
Dooner
Images: 69
Postby Dooner » Sun Mar 04, 2007 1:01 am
dewayne wrote:Dooner look in my albun and you can see what I done to my trailer which is the same one you have.
dewayne
Dewayne,
Good job on that tongue. Looks like that maybe the way to go to be safe. Thanks.
Dooner.
Dooner
Images: 69
Postby Nitetimes » Sun Mar 04, 2007 1:13 am
Dooner wrote:Sdtripper,
Thanks guys.
Yep, that's pretty much what I am referring to. :thumbsup:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby sdtripper2 » Sun Mar 04, 2007 1:37 am
Dooner wrote:Sdtripper2,
Sku #1000215
Model #4X8NF
GVWR- 1500 lbs
GAWR- 2000 lbs
Tires- 480 x 12C
Rims- 12X4JA
90 psi
Single Axle
Thank you Dooner
I uPdated this thread to reflect your information.
http://tnttt.com/viewto ... 446#140446
sdtripper2
Search Garoux
Images: 168
Postby Dooner » Sun Mar 04, 2007 10:40 am
sdtripper2 wrote:Thank you Dooner
Hey Steve, may I call you Steve?,
I'm glad to help. You know, when I bought the trailer, I was going by what info was here. Didn't really see any need to check the info on the trailer. When I got home, I thought I got shafted with 500 lbs less rating. I called the TS store and they assured me that all the 1000215s were all 1500 lbs. I guess when I get that tongue issue fixed, it should be enough for my TD plans. Minimal KISS.
Thanks for updating the info. It'll save someone else the shortage scare.
Dooner.
Dooner
Images: 69
Postby madjack » Sun Mar 04, 2007 11:30 am
Dooner, 1500# axles are what we use :thumbsup: ..................................... 8)
