They're the makers of Flexiride
http://www.ucfamerica.com
Don
Alphacarina wrote:You can't see it in their pictures, but it's really obvious when you see them up close
asianflava wrote:That must need a really steep boat ramp.
Alphacarina wrote:...Since I'm using FWD automotive alloy wheels, I'll have to order me a pair of 2 inch spacers, since the bore on my wheels is smaller than the hubs . . . . but then it looks like I'll really need that 2 inches anyway to keep the inner part of the tire away from the arm
Alphacarina wrote:If the frame rails are substantial (like a heavy 'I' beam) then the cross rails can be well in front of and well behind the wheels...
Alphacarina wrote:I don't think you have to have a cross member at the mounting location - One of the reasons many folks go with the stub axles is because they want to have a dropped floor in the middle of the trailer and that's only possible with stub axles...
SteveH wrote:I have a question about the stub axles and maybe one of your "experts" can answer. I understand there must be a cross member at the axle's mounting location, but must there be two cross members, or a very wide crossmember to handle the load torque applied to the mounting plate?
