shoeman wrote:I just visited a local Dexter supplier to see what they could do for me in case I can't get to talk to an engineer at at the factory. The local guys Dexter book showed a dimension on it for the hub face to inside of torsion arm distance that Dexter's info does not show. His listed that dimension as 5.6" and it is a fixed measurement according to him. That means to get torsion arm to wall clearance you need to use that number to get your hubface to hubface measurement. At least that's what I was told. I was also quoted $260 for the axle, which seems high to me. I tld him I wanted to verify my dimensions before ordering and left it at that.
Can anybody confirm if that 5.6" spec is indeed the case??
shoeman wrote:That's exactly what I was concerned with. If you planned on having your walls cover the frame you do not have enough room to do so.
So I assume on that project your sitting the walls on the floor?
