Esteban wrote:Yes, you can order a Dexter #9 axle with the rubber derated. I ordered a Dexter #9 built with rubber rated for a 1700 pound load for the 5' x 10' teardrop I'm building.
Arne wrote:... the factory setting is fine for now, but after the tear is loaded, may want to move them a bit...http://www.southwestwheel.com/store/c-26-torsion-axles.aspx
WarPony wrote:Arne wrote:... the factory setting is fine for now, but after the tear is loaded, may want to move them a bit...http://www.southwestwheel.com/store/c-26-torsion-axles.aspx
Arne, is the axle you bought come in different weights or do you buy the 2,000 pound one and deal with it? I was pretty disappointed in their website, as far as the description and my email to them went without a reply.
Jeff
madjack wrote:Jeff, that is the axle I bought for my first tear...I spec'd it as a 1500# axle...
WarPony wrote:madjack wrote:Jeff, that is the axle I bought for my first tear...I spec'd it as a 1500# axle...
Did you get the Dexter or the Flexride?
Jeff
Trackstriper wrote:From my understanding, the torsion axles are good right up to their design weight, where they will have the most compliant suspension and ride the best. There is still room left for the dynamic loading that happens to any trailer axle (bumps, normal irregularities in the roadway). That's the difference from "full load" to "shock load". But many people just keep packing stuff into trailers and overload the axle systems, whatever kind of axles they have....human nature. It doesn't hurt to have a little margin for error and spec the axle for a little more weight than you'll put on it. The other extreme is not loading the axle enough and it will be a perhaps too stiff and the ride is harsh as was Rocky's experience, not to pick on him in particular.
