15" wheels and tires on tractor supply 4x8 no floor tra
Postby dmckruit » Fri Jul 11, 2008 1:00 pm
Okay. I am a newbie and just started on this forum. I recently bought plans for the "Tin Top Teardrop" from Stephen Guthrie. He explains in his plans about the problems he had using a Harbor Freight frame and converting from 12" to 15" wheels. I am currently deciding between a 4x8 or a 5X8 frame. Anyway, my biggest concern before I take the plunge is changing the axle to a larger diameter wheel. My question to the group is: Once I choose my frame size, what should I choose next? Should I get the fender first, the wheel first, or the axle first in order to ensure that I get enough wheel clearance?
Thanks in advance. :?
dmckruit
Images: 212
Postby del » Fri Jul 11, 2008 2:48 pm
dmckruit wrote:Okay. I am a newbie and just started on this forum. I recently bought plans for the "Tin Top Teardrop" from Stephen Guthrie. He explains in his plans about the problems he had using a Harbor Freight frame and converting from 12" to 15" wheels. I am currently deciding between a 4x8 or a 5X8 frame. Anyway, my biggest concern before I take the plunge is changing the axle to a larger diameter wheel. My question to the group is: Once I choose my frame size, what should I choose next? Should I get the fender first, the wheel first, or the axle first in order to ensure that I get enough wheel clearance?
My suggestion is get the tyres and wheels first, with these and the frame determine how wide the axle should be. when all squared away find a fender to cover it all up with.
del
del
5000 Club
5000 Club
Images: 410
