TJinPgh wrote:Chartle,
The Tractor Supply trailer Len mentioned seems like a good option. Certainly easier to register. Although, from everything I've been reading it requires a mod to the tongue.
Given that I don't have a welder, I'm not sure how that would work, let alone the additional expense.
The mod really isn't that big of a deal and can all be done without welding.
I used "Bed Rail" (which I trash picked) on a few of mine, 4 bolts and a 2" square "U" bolt. (total $5-6)
The problem is that, and only in my opinion that the tongue doesn't extend back far enough into the frame. i.e. only to the first cross member.
I corrected this by installing 2 pieces of bed rail attached to the outer side rail just ahead of the first cross member to the tongue with the "U" bolt about 18" away from the frame.
It spread the load out a little more evenly instead of only 2 points its spread out over 7.
Again, I never had a problem, nor heard of a problem with the frames in there original condition...just didn't like the way it looked and saw room for improvement.
Not the best drawing, but....
Happy Trails
Len
