Steve_Cox wrote:Danny,
With the spare that close to the axle you probably wouldn't hit the tire from inclines or declines in the road, like a driveway entrance, it would probably be from hitting a pot hole. One thing for sure, it won't clear a cat in the road.
Micro469 wrote:I think a safer place would be to mount it on the under side of the tongue at the front of the trailer. It's totally out of the way there and you wouldn't hit it going up or down a curb. Might affect your tongue weight tho....
arnereil wrote:Be careful, under the tongue might be worse. going up a road or driveway and pulling onto a flat road might hang it up.... you want to be as close to an axle as possible (to rise and drop with the axle).... the further away you get, the more problems you might have.
On top of the tongue, or against the front of the tear is a decent place if the sight of it does not offend you.
Bandit wrote:If you move your jack forward to the straight portion of your tongue, could you not mount your spare vertical on the from surface of your box?
It may distract from the beauty of your box.
Miriam C. wrote:Danny,
Would something decorative go on the upper rear (passenger side) side?
Miriam
jagular7 wrote:Danny, do you care about symetry? If you have a hitch frame under the center of the TD, why not add another offcenter for the spare tire? Then with a little ingenuity, make the spare swing out and become a table like (insert name here) did. (I can't remember the woman's name.)
Though here spare is symetrical in the center, it swings to curb side, then rotates flat to provide a table-like platform.
Would weight be a concern for off-center? Depends on your material you use, plus the weight of the spare.
