HF frame bolted directly to the axle
Postby Denny Unfried » Sat May 27, 2006 6:23 pm
Seems like you could use a 4 inch drop axle that would get you close to the ground. My finished tear has 10" of road clearance with this one and P205R-15 tires.
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Arne » Sat May 27, 2006 6:26 pm
I did the above notching (per Mike's note/pic) and the trailer/car are level with each other: looks good.... any lower and it could drag too easily....
I'm referring back to the red h/f trailer.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby doug hodder » Sat May 27, 2006 8:00 pm
Doc...I wouldn't do it...no suspension and a bolt together frame might require a chase vehicle to pick up the pieces...and if it comes apart, it'll get exciting real fast...just my opinion...for whatever that's worth...Doug
Postby SteveH » Sat May 27, 2006 10:42 pm
I was told once by a "professional" at a trailer parts supply house that you could run a trailer without any suspension, but you had to reduce the capacity of the components by 50%...i.e. if you had a 2000 pound axel, with no suspension, it should be considered a 1000 pound axel.
Have a friend that actually has a street rod luggage trailer like that, and I don't like it at all....the beer is always spewing all over the place when opened. :x
SteveH
SteveH
Images: 42
Thanks to you all for your replies
Postby doctormap » Tue May 30, 2006 7:39 am
Thanks very much for all the input on this subject. I am going to have to weigh the advantages of having a larger interior (Lil Diner) versus having to deal with the effects of having a larger exterior (5 foot height). I will be pulling this with my restored 1948 Studebaker, so I need it to be as aerodynamic as possible, as it doesn't have a lot of extra horsepower.
I like the flipped axle idea, at least that gives me a few inches more to work with.
Thanks again for the input.
doctormap
