Melvin wrote:...Someone should make a torsion axle with an adjuster in the centre.
There really isn't anything inside the middle of the cross-trailer tube of a normal rubber torsion axle. You could cut a narrow-track one across the centre, slip both ends into a piece of square tubing sized to slide closely on the cross tube, then drill and bolt at the required width. The bolted-on "splice" tube would align the two sides.
This would not be as light, stiff, or reliably straight as the original one-piece, but it would be adjustable, and it might be lighter, stiffer, and straighter than two individually installed sides. With care in the bolting design, it might be okay.
It would be like the "universal" or "adjustable" hitch receivers sold for trucks. I wouldn't use one of those if I could avoid it, either...
