shoeman wrote:Now I see what you did. Brilliant! Place the angle such that the nailer strip (which I think takes the place of the long side floor subframe strip) is exposed on the outside of the frame. Screw the floor sheet to the top and the wall base to the sides of that strip and you've got a tidy simple joint. Is this correct?
shoeman wrote:
I see you used square tube for the end of the frame too. How do you attach the floor there?
shoeman wrote: One more question, aint I a pain, typically how many cross pieces are needed or used for an 8' frame? Seems the two end pieces and two more in the middle would do, along with the axle.
shoeman wrote: One more question, aint I a pain...
Leon wrote: The wood set into an angle better be well sealed to prevent it from rotting because of water held by the angle.
Second question.... That would be with these, Deck Screws, very easy to use and strong and effective. Also available in various lengths
shoeman wrote:Second question.... That would be with these, Deck Screws, very easy to use and strong and effective. Also available in various lengths
Straight through the floor into the top of the crossmembers? That would make life simple.
