Mike Spicer wrote:Where are you going to get 1 7/8" square lumber, to fit in the frame?
It doesn't need to be 1 7/8" square, just high, rip it and screw it inside, works fine.
...and use plywood to build up the 1 1/2" size to 1 7/8".
No need for the extra work
I think I would turn the Angle over and put the flat side of angle up and to the outside, thus doing away with the wood stringers. In my opinon they serve no purpose. You have to screw them to the frame and screw your body to the wood stringers.
Why not just bolt your body to the frame.
Drawback here is now you have very weak mounting points for your tongue and spring hangers.
Mike
D. Tillery wrote:Dean, interesting info about vertical down inclusions. I'd like to know more about that. I'm sure I've made that mistake and never even known it.
asianflava wrote:
You could always TIG your trailer frame like Lenny did.
