![Not Certain :NC](./images/smilies/confused4.gif)
Ed
Arne wrote:Filling the entire hub on a tear with grease makes little sense...
I think one of those bearing packers would be nice, but have not bought one... would be another messy item to store, and I'd need a grease gun filled with wheelbearing grease...
Dean Williams wrote:I'm curious how too much grease can be bad for bearings? As long as you are not forcing it in through a zerk and blow the seal, how can it hurt?
Dean Williams wrote:That's what I was thinking. I've packed a lot of bearings, but as long as the rollers themselves are properly done, I can't see any harm with filling the entire cavity inside the hub with grease, as long as it's not pressurized through a zerk.
That said, all the extra grease won't offer much protection to the bearings if they get hot. If the grease around the rollers liquifies, you will have problems even if there is a gob of grease plastered on the inner hub wall.
