Got a new coupler but ...
Postby Ron Dickey » Thu Aug 31, 2006 1:21 pm
I went and baught a coupler for my trailer frame ... much to my dismay the coupler is 2 3/4 inches and the square pole is 3 inch. the coupler is for 3500 lbs. made by master lock.
How can I get it to fit. buy a torch and use a sledge. Attach a smaller rod and have it welded on top of the larger one.
Take it back :cry: and try again. are there 3 " ones or is the next size 4 and then what.
the trailer I am using is an old boat trailer and the old coupler had rusted out.
Perplexed.
Ron D.
173882......173887
Ron Dickey
Images: 787
Postby asianflava » Thu Aug 31, 2006 1:59 pm
I'd take it back and get the correct one. The coupler isn't a good place to "Jerry Rig" as all the weight of the trailer is concentrated on that one spot. It always pays to do it right, especially there.
asianflava
Postby bg » Thu Aug 31, 2006 3:01 pm
You want to buy a 2" coupler for a 3" channel. Even wal-mart normally has them.
Like this
Bobby(, Kim & Wayne)
bg
Postby Jiminsav » Thu Aug 31, 2006 8:32 pm
yes they do make 3 inch couplers..
Jim in Savannah
Jiminsav
Images: 40
Postby doug hodder » Thu Aug 31, 2006 10:25 pm
Ron...I don't know what you mean that the coupler rusted out...but I'd check to make sure you don't have a lot of rust/cancer on the inside of the tube that you are wanting to mate the new coupler to...make sure you have enough good material to attach to....just a thought...Doug
Postby Ron Dickey » Thu Aug 31, 2006 10:57 pm
Thanks guys, I did return that one and found one the right size same day.
Thanks doug I will make a closer look and may need to recut the end and ad new holes.
I am full of set backs but that is also learning new things and technics.
Ron D.
173882......173887
Ron Dickey
Images: 787
